I've been taking my time installing a new set of rotors this winter. After removing my right rear rotor I couldn't believe the play in the upper rear control arm. There had to be an 1/8" of free movement in the upper left arm. :jawdrop: The shop manual says the bolt torque settings should be 81 ft. lbs. This bolt was 23 ft. lbs. I tighten it up to 81 and everything is snug. I decided to check all the other bolts and they were loose as well. Not as much mind you but I had to retorque all the bolts. So boys a word of precaution, tighten your bolts so you don't loose your nuts :zboobie:
