1 - 2 of 2 Posts
With the A/C on, water is leaking in the passenger compartment. From other posts I have read, it seems that the evaporator drain tube could be crimped or clogged. Can anyone help me with this problem?
Check the small rubber tube that is under the car in front of the passenger side floorboard to make sure it is not clogged or stuck together.
1 - 2 of 2 Posts
