Hey All,
Has anyone had any noise coming from a spec stage III clutch from take off? When I pull away from a stop I get a rubbing noise at the clutch engagement point. I also hear it when the car shuts down. I only get it when its from a very slow speed (below 8mph). When Im driving and shifting from 2-3-4-5-6, nothing. The clutch grabs fine at high torque conditions as well. But when the rubbing noise happens, I can hear it and feel it in the car and clutch pedal. Again, its only from a very low speed and from a stop when Im trying to duplicate the noise. Any suggestions?
Thank You,
Jim
Sounds like clutch chatter. Normal with this type of clutch.
I get a small amount of noise with my Stage 3 when pulling away at light throttle loads. It goes away just after full engagement. I just use a few more revs and quicker clutch engagement when I can. I notice it most when creeping along in traffic and I don't use enough throttle to pull forward.
Later ... Larry S.
Later ... Larry S.
Mine is the Aussie clutch. Same here. Why?
I'm used to the typical spec stage III chatter but its not that. This is loud and shakes the whole car. I can feel it through the shifter even. I took it to a service manager friend of mine and he's stumped.
