I recently popped a code p0200 along with the fuse on injector bank 1. I have checked and it is intermitant and appears to linked to the pink wire on that circuit. Has anyone else had this problem? I have removed the wire loom and can't see any damaged segment. Any ideas would be helpful.
Thanks!
-matt
I threw the PO200 code twice one day two weeks ago. I checked all the wires and one was rubbing on the block. Moved it taped it and no more codes.
