Hi Dave & All!
This is Jake from Corvette Concepts. In 1997 I built what I believe was the first Ram Air Induction System on a C5 Corvette.
After 6 changes in Ram Air boxes, I belive we offer the finest cold air system available. Our present system consists of a cast acrylic box 3/16" thick in your choice of glossy red, glossy black, or custom painted colors, over an American made K&N Filtercharger. Our system includes a lower air scoop which is open in the rear to allow air to feed into the air filter and allow water to flow harmlessly out the back through the radiator. We know of no other system on the market that can make this claim. Our system comes with a solid 1/4" plexiglass template which is screwed into positon to allow accurate cutting of the hole for the air scoop rather than a thin cardboard sheet. When removed the template leaves pre-threaded holes to install the air scoop. Our easy access air box removes by simply removing two phillips screws, allowing total access to the filter in under a minute. There is no need to remove the entire assembly to exmaine the air filter. We believe that this system is not only the easiest to install and maintain, but the most solid and safest for your C5. Our guarantee is simple...if you don't feel that this is the easiest install and the finest Ram Air Induction System on the market at any price,we will refund every cent of your purchase price.
Jake Delaney
www.corvetteconcepts.com
941-322-0577
Jake Delaney
Corvette Concepts
Sarasota, Florida
941-322-0577
