After the car was sitting for ab out a week or so, my battery was quite low. When I started up the car, it barely turned over. When it started, the "service column lock" message came on. The wheel was also locked even though the car was running. I let it run for a few minutes, then restarted the car and the steering wheel was free. Now, every time I start the car, I keep getting the same message although, my wheel has been free.
Is there a way to clear this message? It keeps popping up but, the car drives OK. Thanks........
Have you had the Column Lock Recall done?
If not you need to have the Dealer do this.
Be aware that if you had a custom tune done to your PCM the Column Lock recall will wipe it out an reprogram back to OEM specs.
Do I need the "recall" done with an '04 car? There is no way to erase the message?
