Steering locks and must be flatbedded to dlr. GM has said was fixed several times although it keeps popping up ??. Fix is a bypass. This affects man trans c-5's......
I installed the bypass kit on my 02 with no problems. Been running great for several months now.
The kit came with a cigarette lighter adapter to temporarily power the lock and move it to the disengaged position before installing the bypass. I couldn't get that to work, so per the instructions, I just powered the car up, disengaged the lock, then disconnected it. This got me a fault code which was easily cleared, also per the instructions, by removing a designated fuse in the fuse box.
All in all, it took less than an hour to install this. Much piece of mind for me.
Aloha,
Ffen
Very interesting as I was told the bypass unit would not work on the 2002's. I took the bypass off the '98 before selling it, guess I better go ahead and try to see if it will work on the 2002 Z06.
Related Threads
Corvette Z06 Forum
1.4M posts
48.9K members
Since 2001
We’re a forum community dedicated to the Chevy Z06 Corvette. Come check out discussions on performance, specifications, modifications, purchasing, maintenance and more!
