1 - 8 of 8 Posts
Just returned took about 2 1/2 hrs. Talked to tech said it was his first one. No problems :yeadog:
Was an alignment necessary after the fix? :z:
Control arm washer recall
No allignment nessesary. I was told allignment only nessesary if washer fractured.Mine were fine just a simple replacement. :thumb:
No alignment nessesary. I was told alignment only nessesary if washer fractured.Mine were fine just a simple replacement. :thumb:
Yeah I had mine done yesterday too. They at first thought I was bringing it in for the column lock, until I told them it was washers. Apparently they hadn't had anyone in there for that yet. Mine worked out well also and no alignment. I don't notice any difference but then again the old washers didn't have problems.....yet. Glad to have it out of the way anyways! Now on to more spirited driving!
:z:
Same here, I had mine replaced last June 2004 and the washers were fine and no alignment was necessary. Nothing changed as far as the steering and feel of the car. :z:
When I had mine done I stood beside the car and watched the mechanic and it took him 5 min each to replace the front and about a hour each to to the rear since he had to take most of the assembly apart to get to the bolts. He first checked the torque before he replaced. He told me that only 1% of Vettes were effected and that it was a the bolts not torqued enough but they replace all of them anyways.
Doug :cool:
Is this re-call on "ALL" 04's?
1 - 8 of 8 Posts
