1 - 1 of 1 Posts
Just installed a new c5r 427 in my 2001 Zo6. The car has a LS2 intake with a cartech 95mm TB. Took for a short run and found oil all over the engine compartment. The dip stick was pushed up out of the holding tube. The passenger side tube on the valve cover was plugged and vented on the passenger side of TB only. Have done this on one other 427 with the fast intake and LS2 TB. Open for ideas on what to do, will go to the shop this a.m. and look at it again. is the configuration of the ls2 intake diff from ls6 so my vents are not working? or properly hooked up?
1 - 1 of 1 Posts
