Is it simple???.......
Or, is it a big deal.......
Mine will need to be relaced, as it has air voids in it, in several spots......
But, I don't know if it will be a rattle trap, AFTER the fix........
Anyone know??:-?
Time really
Hi there,
It really is just time, as it will take me about an hour to change the dash pad. You have distortion above the center vent, and around the defroster?????
There are about 20 fasteners, and you can really access most of them, except for about 5 of them which are hidden by the center trim bezel.
I dont really think that there will be a problem.
Bestoyou, c4c5
c4
yes distortions, and several places in a 12-16" perimeter around the center vent...............
I have checked 4-5 other ZEEE's, and none of them have this problem.........
There are actually "SINK", holes(voids) underneath the vinyl cover........
I figure over time, and TEXAS sun, these may crack, IF i keep the car that long......but, either way, shouldn't be on a 50k auto........
Also, I hear of a lot of problems with door actuators(lock,unlock) mechanisms, using the key fob's..........and the driver side glass scratching issue is one all should watch out for...
Seems something is Metal to Glass inside the door...........this has been a common problems on ALL GM products I have ever owned......
Thanks for the reply....at least it sounds like they won't have to dismantle the entire speedo, gage assemblies.........;)
