I know they said not to regap them, but I got a few peple telling me the gap should be .055, I know the NGKs are gapped at that when you buy the Iridiums.
I was very careful when gapping not to damage the iridium tip or bend it.
Should I not have gapped them? Should I return the gap to .040? I just a search and seems like overall consensus was not to gap them. Now that I screwed that part up, should I pull them all out and regap them to .040 or just leave them be at .055?
I know from boosting days in my previous car the smaller gap is better when you are adding more power.
Dixit :cry:
So you leaning toward leaving it at .055 or leaving it at the Delco .040?
Dixit
Dixit
Since you already gapped them at .055 I would leave them. I don't think it will make much of a difference.
I've read that iridium plugs should not be regapped. I think I remember reading that the tips have some sort of coating that should not be scratched/damaged.
Since you already regapped/installed them, I would leave them alone. I would swap them out a little earlier than normal.
jmo,
Alex
