From what I can determine, the car has two belts; one long serpentine belt with its tension is controlled by the belt tensioner that is on top, and a second lower belt that I am not so clear about.
What does this second, smaller belt do, and how is it kept tight?
Does anyone have a clear diagram of how these belts are installed? The diagram in the owners' manual is not very good. Part #s would be appreciated.
Administrator
I believe the second belt you are referring to is the A/C belt.
Mike
1. Serpentine belt with tensioner at upper Rt side of engine
2. A/C accessory belt with small tensioner at bottom Rt side of engine
Thanks. I threw a belt at my last DE and I plan on taking spare belts and some coolant with me to my next DE.
