Horrible customer service.
I bought a Dewitt’s Radiator back in 2011, it started to leak in 2014. I returned it and they repaired it. Now in 2022 it is leaking again so I returned it again ! I called and called, left messages after message with NO RETURN Call ! I finally got someone to escalate the issue after calling for 3 weeks and I got a call back from John. He said something in the car was causing the radiator to fail. He finally agreed to send me a new radiator as they could not repair the returned one but said they would not replace this one if it failed !
I would note that the radiator was installed and removed by a GM World Class certified Corvette Technician. If he can’t find an issue with the car who can.
Sleeve Rectangle Beige Font Packaging and labeling
Z06 Tech Advisor
It seems there may be some considerations on radiator providers. Why did you go with a dewitt's instead of AC Delco factory?
Because 3rd party ones are designed to have a higher flow volume so keeping temps down better over OEM one
But nothing new as seen other Corvette owners have bad quality with DeWitt radiators
