Started car and DIC started flashing messages service ABS service active handling etc. Shut off engine restarted and hasn't done this again. Any thoughts or has anyone had this happen?
I had this happen. It was my EBCM (electronic brake control module) and BMPV(????). all replaced under warranty. Total cost was nearly $3000.00! Hope you have a warranty. Do a search"Service AH/TC/ABS" and you will find alot of info.
Check the codes and see what it gives you. Every once in a while, you'll get some weird messages and they won't happen again. When you run the codes if they have an H next to them you're ok, but if there is a C there, then you have a problem.
I'm assuming since the messages aren't there anymore you'll be fine.
Run them and let us know what's up. :thumb: :thumb:
