1 - 20 of 26 Posts
Did I install my rotors correctly?
I am being told that my Drill/slots are back-wards. I installed them not looking at the drill/slotts, but by the "VEINS". I installed them with the veins facing the same way as the stock ones were facing.
When I say veins, I mean the slots/fins in the middle of the rotor. I hope I am explaining it correctly.
It looks like that's the right rear of your car by jack location and caliper orientation, but you can't tell rotor direction by the slots and holes. The vanes should pull the air from the center of the rotor to the outside. Try here:
http://www.stoptech.com/faq/data/faq16.html
Looking a your pic though it does appear to be backwards. Maybe the original rotors were on incorrectly. :crazy: Normally the slots lead into the pad from the outside of the rotor and exit the pad at the inside diameter.
I can't really tell from the photo. Here is the easy way to check. Look straight down at your rotors. The "vanes" inside the rotor should point to the rear of the car. :cheers:
Thanks for "ALL" the input. :yeadog:
Subdriver the vanes do point to the rear of the car, Installation was correct! :coo:
P.S. Like I said I copied the direction of the stock "vanes" they pointed to the rear also.
Thanks again,
M.O.
Additionally, not all aftermarket rotors are slotted the same direction. I just installed a set on a vert. I don't know who's rotors they were but when installed correctly, the slots were machined opposite of my Baer rotors.
Morzoff, what make of rotors are these?
I just installed Baer's which look much different. Very curious.
Thanks again,
M.O.
My pleasure. Glad you got them on right. Big pain to take them off and do them again. Not that I've ever done that... :roll:
Discussion Starter · #11 ·
Red kelly,
These are Brembo rotors, drilled/slotted by Nate at corvette garage. I then had the hat's powered coated black.
See Ya,
Mike
Nice rotors and they do look correct. What about those rubber brake lines? The good steel ones will really improve the peddle.
Morzoff said:
Red kelly,
See Ya,
Mike
Mike, that was a smart move. I bought some used rotors a year ago and was told they were Baer Eradispeed rotors. I bought a new set direct from Baer only to discover after removing my used rotors the Baers are much heavier. 4 lbs each heavier in the front and 1 lb each heavier in the rear That's 10 pounds of added weight :flaming:
Do these rotors make me look fat :zboobie:
I too am interested in those steel lines. I have read and heard of Z owners having leaking issues with the banjos of the steel lines. What is a reputable brand to buy? I had steel lines on my last car, and felt the difference right away playing in the mtns of N. GA! :D
the rotors look great man! :yeadog: I too have these and decided to paint the hats gloss black to match the body. I have taken them into the mtns and they made a good difference. I drive pretty hard in the turns........ :thumb: :jammin:
Discussion Starter · #16 ·
I was thinking about up grading the lines, any good brands?
1 - 20 of 26 Posts
