This intake came with an extension hose and two clamps of different sizes. To me it looks like one of the clamps is slightly too small.
It looks like you need to take the original clamp with the holes for the nipples off of the rubber assembly it came on, and put that clamp on the extension hose which fits on the air cleaner assembly.
Then cut off the nipples that fit on the black unit that was originally designed to fit on the air cleaner assembly to use the smaller clamp???
