· Registered
my driver's side door is starting to really annoy me. basically any music makes the foam behind the door panel squeek now. if you apply pressure with your elbow while driving it stops. is there any easy fix for this? how does the door panel come off? i would prefer to not go to the dealer as they are a bunch of retards and would probably suggest that i refill my wiper fluid to resolve it.
if anyone wants the full audio/visual effect watch this clip :)
http://webpages.charter.net/rsmiles/MOV00308.avi
· Registered
I had the same symptom. It turned out to be a loose window track in my case. Dealer tightened it, and the door now closes with a solid sound like new + no rattles at all. Good luck.
· Registered
To pull the door skin off, follow the directions from Vette Essentials. I did this when replacing my door handles with the VE product. It was pretty simple. I have to pull my passenger door apart in the near future to fix a couple of rattles. Unfortunately for me, it isn't the Bose emblem but something in the door.
http://www.vetteessentials.com/instructions/door_handles/door_handle.html
chris
