Thiele-Small parameters anyone? You can assume an approximate 1 cubic foot air volume for the door interior. If you think you need this for a TS formula for a certain aftermarket driver, consider this: The door is NOT a sealed enclosure and actually acts an enclosure with bizarre porting effects due to the air leakage. Just curious, what are you replacing the (atrocious) stockers with?
