1 - 2 of 2 Posts
When the old one fails, and you are flatbedded, and GM, replaces the defective unit...............
What do they "replace" it WITH?????
Another of the same??...........or a REAL fix???
Hi there,
Basically, as long as the column lock is what has failed, then, they replace the lock actuator itself.
There have been other issues to address this failure, as I have seen pinched wires, BCM issues, as well as feedback signal misreadings.
There are alot of things that customers cannot see when having a failure.
Besttoall, and usually, the lock is the same, as it has been revised several times over the years of production.
Besttoall, c4c5
1 - 2 of 2 Posts
