How to install DRM cooler
Clarifications from prior post:
1) Probably took closer to 10 hours but shouldn't have taken more than 7
2) I was talking about the trans cooler only, not the diff.
3) As I described the elctrical run, I should note the wire was completely hidden in the interior. Easy to tock under dash, console, carpet, etc.
Install info / notes / sequence:
Other notes:Use plumbers nylon tape at brass fittings, blue thread lock elsewhere; directions are good for which fittings to use where, etc.
1) With the DRM kit, you will need to separately get wire, inline fuse and fasteners. I used 14 guage, 20 amp, and 1/4" x 1" bolts with washers and locknuts (7 sets, 5 for the top brackets for heat exchanger, 2 for bottom bracket at heat exchanger) and #14 x 1 (6 total, 2 for bottom bracket for heat exchanger at frame, 4 to mount pump to frame)
2) The DRM kit indeed goes into where the brake ducts are in front of the friver side rear wheel well, eliminating duct - I don't think the loss of the rear duct(s) will be a big issue - I may try to figure a way to re-duct later. I also plan to take out the other rear duct for equivalent brake pad temps / balance. You have to remove wheel / wheel well to get started.
3) To avoid head scratching about brackets - the top of the heat exchanger is held on by a 2 piece bracket - one L shaped, one straight. The L mounts to the metal lip about 2/3 of the way up the (frame / sheet metal) side of the wheel wheel, the straight piece to it and to the exchanger. The other V shaped bracket mounts to the bottom of the exchanger and the frame.
4) The crude diagram showing hose routing that DRM gves you with their pics is a little confusing. they show the nipples on the exchanger facing back, they really face forward, other than that the diagram is accurate.
5) Hoses: the shortest supplied hose goes from pump "out" to bottom nipple of exchanger, the middle length hose goes from exchanger top nipple to T that installs at trans fill, the longest hose from trans drain to pump "in". The longest hose had to be cut, the others didn't. Note of sourse you need to use the supplied fittings, too, not just the T I mentioned
6) Cutting braided hose: I had to cut the long one, and a small cut to clean up the end of one of the other hoses. Cutting properly and installing hose ends / fitting was a bitch and I wasted time and got frustrated til I figured it out:
a) Use electrical tape to wrap the braided hose very tightly.
b) Clamp hose with 2 quick clamps (I used the carpenter clamps with pads on them) to bench / table withing 1/8 inch or less of each other
c) Cut hose between clamps with hacksaw with fresh blade
d) Leave/reinstall a small amount of electrical tape (too much and you increase diameter, and can't install end) at end, install supplied hose end, with pressure and rotation, install second piece of end
7) Other notes:Use plumbers nylon tape at brass fittings, blue thread lock elsewhere; directions are good for which fittings to use where, etc.
8) Install Sequence
a) Cut top right corner off integral bracket on exchanger (test fit and you will see that without doing this, it protudes into wheel weel a bit). Use hacksaw, don't cut into exchanger proper!
b) Bolt bottom bracket to exchanger
c) Hold exchanger in place (against duct), mark for holes in frame for bottom bracket
d) Drill 2 holes for self tappers
e) Install 2 hose ends, install 2 hoses to exchanger (but fill it with ATF first)
f) Install exchanger with bottom bracket with the 2 self tappers
g) Next to install top bracket(s) to metal lip (described above) / exchanger:
i) Attach top L bracket to top straight bracket (1 bolt)
ii) To install this bracket assembly to metal lip (described above) requires drilling 2 holes in metal lip (I clamped L bracket into place with vice grips, in proper place where straight bracket was aligned with exchanger), then installing the 2 bolts
iii) Attach straight bracket to exchanger. Drill one extra hole into bracket thru to exchanger. Install 2 bolts
h) Install L shped fittings to pump; Hold pump in place (make sure you are inside where wheel well will cover it) mark holes for self tappers
i) Install 4 self tappers for pump (don't forget the supplied rubber grommets)
j) Install short hose to pump "out"
k) Install other hose end on medium hose, route back then in to between crossmember and halfshaft, turn to front towards trans fill.
l) Measure length needed for long hose. Route next to hose just meantioned but continue along cross member to trans drain. Remove and cut to proper length (see hints above)
m) Install hose end (the u shaped one), reroute, attach at pump.
n) Remove electric at fill plug, remove plug. Install T / brass fitting at fill (I left this pointing down a bit towards rear to allow for easy / full fill). Install hose end fitting to T.
o) Install brass fitting to hose end fitting at end going to drain plug. Test your quickness here! Remove drain plug and quickly install brass fitting! (probably use a pan, you are not that quick!!)
p) Remove plug at top of pump, fill pump with ATF.
q) Go back to T, fill open end with ATF until full (you'll need hand pump for ATF here). Reinstall plug, electric pickup.
r) Do electric (see preiovious post)
s) Reinstall wheelwell, wheel Done!! :coo:
Start, looks for leaks. Go for a drive!!
