I was looking at these two pads from the national retailers:
Wearever Gold Semi-Metallic Brake Pads - Front (4-Pad Set) (Advance)
Duralast Gold/Brake Pads - Front (AutoZone)
I didn't find anything in this forum about these pads in a search query. Are these good pads to use? They're both <$100 which I'm fine with. I'm not sure I'm ready to drop $400 for the stock pads from GM.
If these pads aren't choice pads for street driving, which ones should I get (I hate brake dust), and where should I get them?
David
Welcome to :z:
Check your pm's.
Here's a bump for you.
I put a set of Duralast gold pads (ceramic) from Autozone on the rear of my C6 Z06 and went to a track day. They seemed to stop fine and no dust, still look new- the semi metallic fronts wore completely away with a ton of dust.
I'll try them up front soon and see if that can handle some track abuse.
