Im a newbie and need to send my ECU back to a shop to get a new EPROM installed and have the current program diagnosed.
Where is the ECU located? I have an 02 z06...
Is there a TECH page for remving the ECU. Location is all I really need though
Thanks in advance
-Jim
[email protected]
The PCM it is in the right front fender behind the right front wheel. Make sure to unhook the battery, then put the front up on jacks stands and take off the RF wheel. Remove the black plastic cover directly behind where the wheel is (about ten 7 mm screws) and take the cover off. The PCM is behind that. Two wire bundles screw in the bottom of it. Two screws hold the bracket that holds the PCM in. One in front is easy to see. The other in the back is impossible to see unless you take the whole quarter panel off. If you take the easy to see screw off, and loosen the back one about half way, then you can pivot the bracket far enough out to get the PCM out without having to remove that pesky back screw. Installation is opposite.
http://www.z06vette.com/forums/showthread.php?t=82123
