1 - 10 of 10 Posts
· Registered
Tonight Cop Bait and I went out with his factory headlamp equipped C5 and my Euro (T84) equipped C5 and did some rough comparisons. Here's a large graphic showing the difference between a US high/low system, a Euro system with factory wattage bulbs, and a Euro system with 90/100W H4 bulbs. There is quite a noticeable difference.
The data:
I apologize for the size, but this is the smallest reasonable size to still see the difference.
Of particular note is the "hot spot" that the US lamp pattern has - the Euro beam pattern much more effectively spreads the light across the road, including the shoulders both left and right, for better visibility. When properly aimed, they both reach about the same distance out in front, but the Euro lamp permits better overall visibility of the entire road surface including the shoulders, whereas the US lamp concentrates most of its power on the hot spot.
In the high beam shots, you will see Cop Bait in the flesh, holding up a large ~15 foot tall section of abandoned PVC pipe we found where we took the pictures. You will notice that the PVC is most clearly visible with the Euro 100W high beam, but is still very visible even at the top with the factory wattage Euro 60W high beam.
With the US high beam, you can barely see that Cop Bait is out there, and the PVC is all but invisible. Just behind and to the left of Mr. Bait was a construction trailer with a reflector on the rear - in the US high beam the reflector makes no appearance at all, and with the Euro beam you can see it in both pictures, although its much more visible with the 100W bulb than the 60W bulb.
Finally, you will notice that, because the Euro assemblies are properly aimed, the furthest "reach" of the low beam is the same for both wattage bulbs, but is brigher with the higher wattage bulbs. The higher wattage bulbs really shine (pun fully intended) when high-speed or very dark driving conditions permitting the use of high beams conditions are present.
Pictures don't do the difference justice - the high beams are like a spotlight illuminating the entire night.
All testing was done with the foglamps turned off.
Let's hear your feedback! The total cost of the Euro lamp assemblies was $64, the harness used to run them is roughly $90, and the bulbs themselves were around $15 each I think. One of the absolute best upgrades anyone can make to a US C5, even if you just go with the factory wattage bulbs that come with them.
Hope someone finds this helpful.
Brian - Y5116
NCM Business Member
Yellow/Black '00 Coupe
12.6 @ 115 MPH (2.14 60' time)
329RWHP/338 RWTQ
"Redshift" on http://www.c5forum.com
http://www.c5store.com/
· Registered
Since I don't have a reasonably priced source for the bulbs themselves (as far as I know - I have a source for everything else under the sun so I'm sure one of my suppliers has these) just yet, and you'd already have to go to another place to get bulbs, I figured just the harness for now.
Also, the GM assemblies are cheap from GM; I'd have to mark them up a bit...
Feedback is always welcome
· Registered
The assemblies are from a GM dealer, and the harness I installed is a prototype that I'm going to begin selling as soon as the final changes are made to it. If you opt for the factory wattage Euros (probably sufficient for lots of people) I already sell the pigtails that make the job literally plug and play. Check the link in my signature to the Corvette Store.
· Registered
Brian, see I spell it that way when I am not talking about your wife.
Let us know when the HD unit is for sale.
Carl V. *****Authorized Zaino Distributor*****
Huntingdon Valley, PA.** 2000 Magnetic Red Convertible **
MN6,F45,QF5,AQ9,AG2,CJ2,T96,B34,AAB,UN0,U1S,JL4,UV6,T82,N37
** Corvette Club of Delaware Valley **
www.hcvind.com
E-Mail: [email protected]
· Registered
Discussion Starter · #9 ·
Funny you should ask /phpBB/images/smiles/icon_smile.gif We just got all the parts required to build the initial kits. They're in stock right now, I just have to re-do the order page.
Keep watching the "What's New" page for details, or sign up for the "What's New" e-mail list on that page. I'm afraid I didn't order enough for the initial kits and that they'll sell out too quickly, but we shall see.
· Registered
Discussion Starter · #10 ·
BTW, ignore my message regarding a source for the bulbs. I found that PIAA has some nice 90/135W halogen H4 bulbs and we're shipping these with the kits. So now the kit comes complete with GM assemblies, the harness, and the bulbs. Plug and play.
Please note that I made a slight error in the above pictures - for more information, and to save me from retyping it all, please visit here:
http://www.c5forum.com/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=1&t=000338
Sorry for posting this from another forum, but it was a lot to re-type.
1 - 10 of 10 Posts
