Does anyone know if the express down window function is a programable function??? While both windows still go up and down, the express feature doesn't work on either one of them.
The only work on the car was an oil change and they did the fix for the column locking recall at the same time. Did the dealer screw something up???? Thanks.............
It's not programable through the DIC. I'm sure it could be programed with an LS1 edit or comparable unit.
charliet said:
Would reflashing the PCM, (in doing the column recall) cause the problem????
I doubt it. I had the CL recall done too and have no problems with my windows.
