1 - 8 of 8 Posts
What has everbody being doing with the left over passenger side valve cover crank vent hose that does not have a place to hook into where the stock TB had a place. Do you run it down to your aftermarket air cleaner or your bridge?
The complete instructions said " here is your TB"
Ran a longer hose into the carbon fiber air bridge....had to cut a hole in the side of the bridge and used a rubber grommet. Looks like it was ment to go there!!
That is what I thought but you would think they would have suggested that.
I put a filter and catch can and mounted it in where the battery sits looks great.
I thought about that and still might do it but I think a little sucking would be good for it after the catch can filters the oil.
1 - 8 of 8 Posts
