After i changed the clutch to stage II spec and went to a b&m shifter, i get faults after a few minutes of driving. They are for abs and traction control, then you cant turn traction control off or on anymore, does it mean they are both not functioning correctly? Any advice plz?
i would guess there is a wire unplugged somewhere that was disconnected during the clutch install,mabye one of the rear wheel speed sensors.also a wire could be pinched and give the same result.what codes do you have? do a search on this site if you don't know how to retrieve them.knowing the code could take you right to the problem.
It sounds like they didn't get the rear abs sensors plugged in good ! Pull the rear wheels and check them !
Rob
