The numbers are lower than I expected, but that seemed to be the general concensus of all 20 or so guys that went on the dyno that day. I just really wanted to get a baseline for next year when I start adding on.
Well, here they are: 335.4 max hp. 338.7 max tq.
why do you think those numbers are low? doesn't that work out to be about 394hp at the crank? 9 over advertised is pretty good.
what were you expecting?
Not really upset, just looked like they were on the low end of the dyno #'s posted in the "performance data section" for '01's. I know that it's hard to compare cars on one dyno to another. Just trying to get a baseline for next year.
I was running very lean, but the car was cooled off for about an hour before testing. I figure after a warm up the A/F would be normal.
Don't get discouraged. You simply can't compare different dyno's run by different operators. The littlest miscalculation in weather varaibles makes 10rwhp swings easy.
I dyno'd almost exactly the same numbers and at the dragstrip I run just as quick as the guys who dyno'd 350rwhp.
Dyno racing isn't real racing.
