1 - 2 of 2 Posts
I am regrettably selling my 2003 Corvette Z06 50th Anniversary Edition
Difficult to find Electron Blue
55,XXX miles
VIN1G1YY12S635127741
No accidents
I have had this car since 2013 but need to sell to make room for another vehicle and because I haven’t been driving it as much as I would like anymore.
I would classify the body as an 7.5 and interior as an 8.
It has been well taken care of but has seen the wear from a car that was regularly used on public roads.
It has used fully synthetic fluids, Redline wherever possible with regular changes.
The following modifications/repairs have been done to it and are still in place.
Turn1 upgraded steering pump
TPIS External Oil cooler
C6 lowering bolts
Track alignment and corner balanced.
Square wheel and tire setup 2 sets both 295 width on 18” wheels (TSW nurburgring 18” track wheels, OEM c5Z06 Speedline 18” wheels)
AP Racing 6 pot Big Brake kit from Essex Racing PN 13.01.10011; CP5060 Endurance comp brake kit
2 - OMP ARS Fixed Back racing Seats. 1 installed as driver seat, stock Z06 in passenger for now, other two seats in storage and included. I can install the Driver stock seat for you if so desired.
Brey Krause harness bar
Pair of Corbeau 5 pointt harnesses
C6Z06 shifter assembly
Skip shift elimination
New Reverse block out solenoid
Full front brake ducting kit, will need new flex hose section
Elite Engineering Corvette PCV Oil Catch Can - LS6, Silver, Nickel Plated Fittings
Direct tap mirror radar detector mount and wire
I-Pod Aux wired kit for stereo
Front end clear bra
There are some extras that are available and I prefer to sell with the car. If there are a couple items you don’t want that is fine, but I priced the ad for the car only, the extras are being thrown in due to my need for the space they currently take up.
Asking $23,000 Or Best Offer. No trades. Please email me at [email protected]
In the subject line please include 'corvette ad' so it doesn't go into my junk folder.
Please let me know if the link for the photos doesn't work for you.
https://drive.google.com/open?id=1kIUtlNiNiPKIHrnNt126b1UQdkjSP93-
Thank you for your time and I look forward to speaking with you.
Extras as follows:
Rear diff axle seals
Rear Axles
Adjustable Anti-Roll bar end links
Extra used air dam/chin spoiler
Stock front rotors
Stock rear rotors
Stock front calipers
Extra stock intake box
New Steering fluid reservoir
Stock c5 shifter assembly
1 Moog rod end
1 set of ferodo DS 1.11 track pads, fronts fresh, rears 2 lapping days
1 used set of factory front brake pads for stock calipers
1 set of carbotech bobcat 1521 front pads for stock calipers
3 sets of front carbotech xp10 pads for stock calipers
1 set lightly used stock carbotech 1521 bobcat front pads for AP calipers (on car)
1 set lightly used stock carbotech 1521 bobcat pads for rear (on car)
Various redline synthetic fluids, Mobile 1- 10w 40 high mileage synthetic oil
1 - 2 of 2 Posts
