So I have M&H 325/45/17 on the rear of my Z. The inner portion of the tires have worn significantly more than the outer edge. Is there any parts to buy to get them to sit flat? So I can Use the whole tire at launch. Or is there just some adjustment I need to have done?
Sounds like a 4 wheel alignment is in order. (Just my best guess).
Discussion Starter #5
Yes. I've had the car aligned. They've told me its within factory specs. And not sure if it has been lowered. I'm guessing it has been. Because if I hit a bump with the 28s on the rear. The tires will rub the inner plastic in the fenderwell. And thx for all the responses guys. Just trying to be able to use all the tire to hook up with.
