I was bleeding brakes for track day after putting new calipers on and the reservoir got too low introducing lots of air into system. I have a feeling I need the abs flushed to rid the air. I'm in puyallup and need a trustworthy shop who has a tech2 and knows what they are doing and isn't to far from me. Thanks!
Tech2 ABS issues
I was bleeding brakes for track day after putting new calipers on and the reservoir got too low introducing lots of air into system. I have a feeling I need the abs flushed to rid the air after a soft pedal experience at the track even after i bleed the brakes twice. I'm in puyallup wa area and need a trustworthy shop who has a tech2 and knows what they are doing and isn't too far from me. Thanks!
Multiple threads are not allowed. Threads merged...
You shouldn't need a Tech 2 to bleed the brakes. The only time you would need a Tech 2 is if the ABS module was removed, then you would have air in the modulator portion. Bleed the brakes the way you normally would.
Just to be safe, after bleeding the brakes normally, find a deserted road and make several stops hard enough to activate the anti-skid, then refill and bleed again.
If you do this, do it in the rain. Easier to get into the ABS and easier on the tires. I think it's a good practice to get used to the car under full ABS lockup for when you really need to.
