Welcome Aboard the good ship Z06
Here are some/most of the differences
differences between 2001 & 2002 & up:
1. The LS6 engine standard in the Z06 increased from 385 to 405 horsepower. Torque increased from 385 to 400 lb-ft.
2. Front fender badges for Z06 models included the 405 HP designation.
3. LS6 exhaust back pressure was reduced by 16%
4. Cam shaft was redesigned resulting in increased lift and a 5% increase in air flow
5. Valve spring material composition was changed to increase seat load by 14%.
6. LS6 intake and exhaust valves were a new, lighter design.
7. The valvetrain weight was reduced by 0.81 pounds, which improved valve seating at high rpm.
8.Airflow over the LS6 MAF sensor was increased by removing gridwork
9. MAF software was recalibrated
10. LS6 aircleaner housing had a larger intake
11. Wheels looked the same BUT they were cast spun instead of forged for a weight savings of 1.3 pounds per car
12. rear shock valving was changed
13. Improved clutch
14. Ticker front anti-sway bar
15. New front brake pads
16. HUD was standard
ALL '01 LS6's DO NOT HAVE AN OIL CONSUMPTION PROBLEM!!
http://www.z06vette.com/forums/showthread.php?t=61257&highlight=oil
