I bought my low profile jack from Harbor Freight. I know most of you are going to say it's junk, however I have never had a problem with it. It is their low profile aluminum racing jack fits right under the sides, a few pumps and good to go. It is only rated at 3000 lbs but I have used it to lift the rear axle in my 5500 lbs F150 with no problems. Obviously I wouldn't leave the car on this jack for long periods of time but it works for what I need it for. I did invest in a high quality set of jack stands. I'm not crawling under anything without the added feeling of security of a good jack stand.
I don't go out of town with my car so have never really worried about a flat tire. I have gotten several nails in the past and have always had time to get home, take the tire off and get it fixed at a local time shop. Every time I get in my car I just run though the DIC to check tire pressures, and usually check them after I am on the road just in case. I could have stayed with the OE run flats but I feel that those tires were such a poor compromise over non run flats that the piece of mind just wasn't worth the loss in handling and comfort.
