What does this mean? I have to get my car California smogged. Is this going to cause a problem?
G
CARB
Once every four years. If you plan to keep your car that long, it takes five minutes to reinstall the stock airbox.
None of the aftermarket intake systems have CARB certification. Your car would smog perfectly, since the fuel trims reset to the factory 14.6 : 1 a/f ratio.
WOT is the only fuel trim (Open Loop) that does not run stoichiometric. That's why the smog test does not sniff at WOT.
Call me with any questions Monday.
Thanks again for your purchase. Enjoy.
Jim Hall
