Has anyone installed a harness for autoX? Any tips?
Their bar is not DOT aproved. I talked with them about it and they said it was not certified. They tested it and said it should meet the requirements. ???
On 2001-05-07 10:45, Gordy M spewed forth this drivel:
Brey-Krause makes a high quality harness bar (stainless steel) and also are DOT approved.
I will agree on the BK bar, it is what I run as well, the install is VERY clean, and VERY solid... you can also take it out and it will not even scratch a single item... it looks like it is made as part of the car... I was able to install mine with the seat in with no problems.
You can get info at http://www.bkauto.com Elseware in the forum is info on the install procedure. The most time consuming part is separating the power seet connector--no rooms for your hands to get at the little bugger. It helps to unbolt the seat completely and carfull tilt it to get a better angle.
Have put one in my car and a friends--they work well and allow you to use the stock seat belt also.
