1 - 11 of 11 Posts
I am curious as to the amount of "pain" involved in a DIY cam only mod.
Has anyone done this in their own garage with only jack stands and a hyd jack?
What is entailed?
Jim
I've done it and it takes about a day and a half including the springs. I'm doing it again next week when I install Andy's Procharger. Take a look at www.ls1howto.com for detailed instructions.
Discussion Starter #3
Thanks man!
Thanks. Looks like a good site.
D.J.
I used the same site as torchedz referenced. I did it in my garage on jack stands. There would probably have been some advantages to using the base auto shop. I don't have air tools...some of the air ratchets would have been nice and really cut down on the bloody knuckles! :eek:: It was my first time in an engine in a long time and I found the instructions to be right on. It took me a little longer...more like two full days. I would definitely do it again! :thumb:
I did mine in my garage with Jack stand. It took me about 3 days total, spread out over a weeks time. Not my daily driver, so I was taking my time. It was actually fun for me to do and I learned a lot about the car. The hardest part I think was removing and installing the pulley, getting some of the accessories off, and installing the new valve springs. I used the same website mentioned above.
Did you have any problems removing and reinstalling the rack? That is something I have never done and would like to do the cam install myself next time.
Thanks, D.J.
The rack was no problem at all. It came right out easliy without trouble. You dont really remove it, you move it out of the way.
As the others said, follow the directions on ls1howto.com it is not hard, just a little nerve racking the first time. Remember you need the proper tools though. Valve spring compressor, pulley remover/installer, and a method to holding up the lifters and valves.
If you take your time it will be no problem at all. Do not set a timeframe, and do not try to do too much in one day, you'll go nuts after about 10 hours.
It took me about 2 days, but the second time around I'm sure I could do it in 1. Remember if you plan on ever installing underdrive pulleys now is the time.
While you are in there, I would also highly recommend better push rods and timing chain. They both have to be removed anyway.
As far as pain, there were far less bloody knuckles suffered than when I put in the headers.
Good luck, keep us posted on the progress and if you get stuck we will help as much as we can...
Dave
Its pretty easy actually lots of work but nothing really hard. I used the heat the pulley in the oven trick this time and the pulley slid right back on!
1 - 11 of 11 Posts
