After your aftermarket header installation did you guys go back and re-check the torque on your header bolts? About how many miles, or how much time did you let elapse before you re-checked?
I ran a socket over them once to make sure they didn't loosen up. What I do when I have the hood up for what ever reason, is check for leaks, which would be evident by exhaust soot.
If you used the steel gaskets chances are they are fine. If you used a composite gasket you will definitely want to re torque after a few heat cycles.
I used the stock bolts and the LS1 header/exhaust manifold gasket. I havent retorqued them or checked then since I put them on in Jan 05, no leaks though.
I used the Breslin locking bolts.
I haven't needed to re-torque them ... and so far (over 1K miles) there hasn't been any leaks with the composite gaskets that were supplied with my headers.
By the way, I hear a lot of talk about using the factory steel gaskets with your headers. I'm sure it works for most, but IMOP it's asking for leaks.
Think about it, even with 1/4" flanges, headers are not machined as true as a cast iron exhaust manifolds. :eek:
Headers need the extra material in a composite gasket to provide the "filler" for a good seal.
Best of luck to ya. :zboobie:
LG reccomended them over the composite ones, I have both but used the metal ones.
