1 - 2 of 2 Posts
Attached is a link. Is this a good deal on a Head/Cam set up as compared to AFR 205s and a G5X3? Anyone with good suggestions/comments is appreciated.
"This Head and Cam Package is a standard part of West Coast Corvettes 442 HP Stage IV Package. These heads are supplied to WCC by Lingenfelter Performance and are unsurpassed in performance and reliability. They are initially machined on a CNC mill and then meticulously hand finished. The bowls are blended and the stock valves are replaced with larger stainless steel valves that are given a 3 angle valve job for optimum flow. The camshaft is ground to West Coast Corvettes specifications and is not a regrind. They're made new from billet steel. This kit is a great addition for anyone who wants to be the one to beat."
http://www.westcoastcorvette.com/shop_online/prod_detail.cfm?id=72
There is no doubt LPE makes good products. If you already have LS6 heads, your old ones are worth 800 to 1000 toward AFR heads. LGM or Andy at A&A can fix you up with head/ cam package at a good price. I suggest you give them a call. :z:
1 - 2 of 2 Posts
