new to the forum. Just purchased 2016 ZO6 ZO7 on the East coast and brought to Colorado. The check engine light won’t go off, I’m pretty sure it’s because I can only get 91 octane here. It didn’t start till I got west of the Mississippi where I could only get 91. Any suggestions? I did disconnect the battery to try and reset the computer it’s works for about a week.
Welcome aboard. You should find out what the code is rather than assume it's 91 octane. It really should be ok on 91.
Yeah I had zero trouble until I got on the west side of the Mississippi and put in 91. Now the other thing is am I getting actual 91, it’s a conundrum.
Not sure about a 2016 but I know on the C5 versions you can see what the code is through the buttons on the right of the dash.
I don't remember the sequence ( I use a code reader) but if you search the board you might find it.
EDIT: Just did a quick check. the C6 does not have that feature. You will have to use a code reader.
