Hi everyone,
I recently received front and rear Durastop Ceramic Brake Pads from GM Parts Direct. My question is, the rears come with two stick on pads, however, there are NO stick on pads for the fronts. From reading several earlier posts, the stick on pads were received with the front pads. I did notice that the fronts appear to have a riveted on backing plate, whereby the rears do not. Was I shorted the stick ons for the front or is this a new design with the front backing plate already riveted on? I don't want to install them without all of the goodies. Thanks, John
Depending on your driving habits, you may not want the anti squeal pads anyway.
The ceramics don't usually make any noise, and in my case the stick-on pads ended up melting and working their way out of the caliper. I removed them a couple years ago and haven't had a problem since.
ttt
