:lol: You have 800 RWTQ...I wonder what the problem is!Sack Rat TT said:Traction is good but not perfect with the Pirelli's. However, when my 335X19 P-Zero's are worn out I am going to replace them with 355X19 P-Zero's. The 355's are OEM on the Ferrari Enzo. No traction in my car until 4th gear ond only on sticky, smooth pavement.
Zrod said:Would have a better basis to answer if you'd post your rwhp and rwtq.
You might be in Sack Rats league, where no matter what you try won't be of much value.
I switched from a Michelin 345/30/19 to a 355/25/19 Pirelli on a 19x13 and noticed a huge difference in traction. I was spinning 1st, 2nd, 3rd, and 4th on those Pilot Sports and it was getting on my nerves! :mah: IMHO if you only have 500 RWTQ depending on your power curve the Pirelli or the Nitto DR (from what people tell me about them) are a good choice. Good Luck! :guiness:rz01 said:Good point. I'm at 500 rwhp, 500rwtq.
I am hoping the Nitto's can do the trick.
Zrod said:RZ01,
I'm running similar hp and tq to spdrcri and I concur. From a 40 roll in second, with Nittos', she hooks pretty good. From a dead stop, ya still really got to feather the pedal or I'm still smokin them in 1ST and 2ND and 1/2 of 3RD.
If your running the Magnuson setup traction will be a little harder to find in 1ST and 2ND due to all the additional low end torque. Best of luck to in finding some decent traction.
It's not an everyday driver so they are wearing well ! The only time they've been heat cycled is when I drop the clutchTHRLSKR said:Rob -
Are you running the 305s on the stock z06 rims? How is the tread wear so far? Did you have them heat cycled?
Antivenom 447 said:I switched from a Michelin 345/30/19 to a 355/25/19 Pirelli on a 19x13 and noticed a huge difference in traction. I was spinning 1st, 2nd, 3rd, and 4th on those Pilot Sports and it was getting on my nerves!
Exactly. :yeadog:WA 2 FST said:I can't compare the RII tire compared to a wider (335mm) PS2, but there is no way the PS2 will hook up like the 555R.
