While running the car today got check engine light and found the following stored codes:
P0171 Fuel Trim System Lean bank 1-B
P0174 Fuel Trim System Lean bank 2-B
P1431 Fuel Level Sensor 2 Circuit Performance -C
P1433 Fuel Level Sensor 2 High Voltage -C
P1626 Theft Deterrent System Fuel enable Circuit -C
U1096 Loss of Communications with IPC
U1064 Lose of Communications with DCM
B2282 Battery #1 Fault DCM-LEFT
B2284 Battery #2 Fault DCM-LEFT
U1064 Loss Of Communication with DCM (No SOH Message Received -RFA
B2283 Battery #1 Fault DCM-RIGHT
B2285 Battery #2 Fault DCM-RIGHT
Cleared codes and only the following reoccurred:
Any input on what might be going on? No drivability problems. Have Haltech intake and that's it for mods aside from CLB.
Thanks,
Scott
Thanks,
Scott
