1 - 11 of 11 Posts
Hi Everybody,
I noticed that my left headlights is slightly higher than the right one. Do you know how to lower my left headlights so that it will be level with the right one?
Thanks in advance,
Tambeng
Hey Tambeng....
Do you mean that the whole physical headlight is higher in it's compartment? Or do you mean that it is aimed higher?
Dan
Hi Sigung,
It seems like it's aimed higher. Kind of strange :)
I just don't know as how to adjust it.
Appreciate any inputs,
Tambeng
Hi there,
In order to readjust the aim of the light, you will have to remove the bezel plug on the inner side of the headlamp.
Now, once that is done, the screw located inside the hole where the plug is, is your horizontal adjustment.
The screw located below, and to the rear of the lamp assembly is the horizontal adjustment.
You can use these 2 screws to correctly adjust your headlamps.
Please let us know how you make out, c4c5:eek2:
c4c5specialist said:
Hi there,
I would bet one of those should have been vertical? :roll:
MAN,
DO I NEED A COFFEE OR WHAT??????:(
Anyway, you are correct, the one in the hole is the horizontal, and the one below and to the rear is the vertical.
Boy, I gotta get back in the groove.
Besttoall, c4c5:eek2:
Discussion Starter · #10 ·
Thank you everyone, that works like a Charm!!!
Good luck also to you fcalmes, hopefully the economy is picking up and btw, I also do have a Ford Taurus and very satisfied with it :)
Tambeng
1 - 11 of 11 Posts
