1 - 2 of 2 Posts
How much alky are you spraying?? Right now, I'm spraying a 375ml/min nozzle on my Sno Boost Cooler at 140psi, the max pump pressure with this kit. With my progressive controller, I'm starting to pump at 4lbs. and full on at 6lbs. Straight methanol. Seems to run great...no stutter, lively as hell up to 10lbs of boost. What are you spraying? The Snow site and info is lacking......They don't tell you the spray at 140psi that they ship their pumps at! Help??? :-?
Roger
1 - 2 of 2 Posts
