1 - 10 of 10 Posts
I'd say 100.00 is on the low side. More like 150.00. Let us know what they charge you. :cheers:
ok,i will
i am jsut trying to udnerstand what takes the most time, since the rear shocks are so easy, that they should take like 5 mins to drop the old ones and another 10 mins to put the new ones. i don't know about the front ones.
atoyf said:
ok,i will
Shops make there money not by how long it takes them, but what the Flat Rate manual says it takes. Any Mechanic worth his salt can beat the the manual time in half, In other-words, If the Book says 2 hours to R&R shocks as an example a good Mechanic will do it in 1 hour or less. The exception is factory warranty repairs. A lot of Mechanic's hate to do Warranty work. General Motors for instance cuts it real close. :z:
I did mine myself, the rears was easy but the fronts was a different story. I used the McRat method on the fronts, which consisted of compressing the shock and the zip tying it tight and then taking it out. Just make sure your zip ties hold. It was really not that hard after I figered out what I was doing. :crazy:
My buddy and I did it on the floor in his garage in about 2-2.5 hours all four.
1 - 10 of 10 Posts
