See sig for current mods. With old toyo ra1 combo (275/40/17 front and 315/35/18 rear) car had mild understeer to neutral.
With new Cup tire combo of 295 front and 315 rear car is now neutral (barely) at turn-in but during track out is oversteer under power pretty badly. Played with tire pressures to even get it there.
Fun but want more neutral with a touch understeer.
Was debating about adding stiffer (larger) front sway bar combo??
What should I do?
Discussion Starter · #2 ·
Forgot to mention alignment. Went toe in in rear 1/6 total and -1 neg camber each side figuring that might help me plant better.
Front is 1/8 toe out and -1.4 camber.
I know I need more camber but I drive to track so dual car.
The answer to your question(s) is ^^^^up there^^^^ in the STICKY labeled Basic Suspension Set Up and Trouble Shooting Algorhythm.
Look under corner exit oversteer.
You may need more rear shock rebound or less Rear Toe IN.
However, I think your alignment is not optimium and you are under driving the car; even though you say the car is now more neutral if the alignment was more agressive you would be able to drive at a higher limit. Ie the understeeer would still be there and you might need a little oversteer on corner exit.
You need to learn how to quickly change your settings at the track. There is no compromise setting for track and street.
Before you start making radical suspension mods, you really need to take some tire temps after a hot lap...and see how your tires are performing. Like DJ said, it's hard to find a compromise between track and street, but your numbers don't look too bad.
Your toe out is a bit much for me (which helps your turn in), but I don't think that will solve all your problems. You also have quite a bit of toe in on the rear too. Definitely try reducing your toe out in front and use just a touch of toe in on the rear (1/16th). That much toe in also hurts your straight line power (scrubs speed!).
I don't know what kind of sway bar(s) you have on your car, but if it's a bone stock set up, the T1 front sway bar is cheap and easy to install and would provide you with some more push and balance the car out a bit. The endlinks are a bit clunky and will make your car ride a bit rougher, but will help it out at the track. Compromise, compromise, compromise....
I am always looking for the free lunch.
After years of drag racing and screwing with cars constantly every day I find myself way to damn lazy to work on my car so I usually just try to get it generally right with little effort.
:screwy:
So adding a little more rebound to my sa penske's in the rear should help. The alignment I need to get done again and have them mark with nail polish a serious setting and then a street setting with the camber.
Thanks for the quick help.
