well guess what :) i was working on my lights and well i dropped the PIN that holds the headlight to the battery motor in under the battery area :( i can't find a way to access it. So how do i get the pin out?
1--remove battery and battery tray.
2--or remove right front wheel and remove plastic inner fender panel that protects the PCM(7mm bolts)
Thanks Z11409
i did the first method and well let me just say that was a PAIN and all bec i just dropped one bolt :mah: oh well but i got it out and everything looks cool now. :) Thanks once again
MrKool said:
Thanks Z11409
Going through the fender is easier, as I learned from a similar experience. :thumb:
