I have them....
They came with no instructions what so ever.....
And they seem like they wont fit from the front of the car, do you have to insert them backwards or what??
Whats the deal with these things????
You have to put the screens inside the duct and pull outward.Use a stiff wire to pull the screen back flush with the duct hole.They snap into place and require a lot of patience.Good luck.
Thanks :guiness:
I installed these on my car, and they were a pain in the @$$ !!! :mad:
The way I did it was by putting them in at an angle and working the bottom in first so that if I scratched any paint, it would be inside the top of the brake vent where it is not visible. Needle nose pliers are a big help. As someone stated above, PATIENCE is key.
If you are going to put them in from the front put masking tape around the opening to prevent scratching.
Thanks guys, I'm gonna give it a try after this 1" of snow we are supposed to get clears out.... ;)
