how do you get the master cylinder out in a c5?
I have the roll pin and line removed from under the hood, when I looked under the dash I found the clip to remove the end of the master cyl.
BUT :bang:
HOW do you get the master out, there is a big metal plate in the way and thick rubber matt/sound deadening behind it...
is there 2 studs and nuts behind all that crap? or do I just spin the master some and push it out?
I am looking for someone with VETTE experience, as it seems the f body cars are different...
When I had my Adjustable Master Cylinder put in, the vette tech said it was pretty easy...spin and push out. But to be on the safe side since I didn't do it myself, pm C4C5Specialist...he is a vette tech.
I just took the clutch master cylinder out of my C5 Z06. Buying the 7 dollar tool to disconnect was worth it. My issue is that I can't get the brass fitting out of the end of the Old Master so I can put it on the new one. Is there some secret to this? Do I need to buy a new brass fitting
