Are there any diagrams about taking the radio out of the dashboard of the 2001 Z06? I want to hook up my portable mp3 player and there is an "Aux" button below the "CD" button which I am guessing the radio has auxilary rca jacks on the back. Only problem is how do you take the thing out so I can hook it up?
There are no aux jacks in the back. That is for the factory cd changer.
Here is from the GM manual. It is pretty straight forward. Hope this helps you.
Radio Replacement
Removal Procedure
Remove the front floor kick-up panel. Refer to Kick-Up Panel Replacement - Front Floor in Interior Trim.
Remove the cover from the I/P electrical center.
Remove the RDO/CD MiniFuse® #5 from the I/P electrical center.
Remove the console. Refer to Console Replacement in Instrument Panel, Gauges and Console.
Remove the I/P accessory trim plate. Refer to Trim Plate Replacement - Instrument Panel (I/P) Accessory in Instrument Panel, Gauges and Console.
Remove the screws retaining the radio control to the I/P center support bracket.
Begin to remove the radio control from the center support bracket enough to access the connectors at rear of the radio control.
Disconnect the electrical/audio and coaxial cable connectors from the radio control.
Remove the radio control.
Installation Procedure
Connect the electrical/audio and coaxial cable connectors to the radio control.
Install the radio control into position in the I/P center support bracket. Align the radio control locator tab into the center support bracket locator hole.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the radio control retaining screws. Tighten
Tighten the radio control retaining screws to 2.5 N·m (22 lb in).
Install the I/P accessory trim plate. Refer to Trim Plate Replacement - Instrument Panel (I/P) Accessory in Instrument Panel, Gauges and Console.
Install the console. Refer to Console Replacement in Instrument Panel, Gauges and Console.
Install the RDO/CD MiniFuse® #5 to the I/P electrical center.
Install the cover to the I/P electrical center.
Install the front floor kick-up panel. Refer to Kick-Up Panel Replacement - Front Floor in Interior Trim.
Document ID# 221816
2003 Chevrolet Corvette :z:
