1 - 1 of 1 Posts
Lancee Perfector Hyaluronic acid restores elasticity, reduces wrinkles and stimulates the production of collagen by the skin, coenzyme gives the skin a healthy look. It is advisable to choose caffeine-free, fragrance-free and paraben-free products that dry and thin the skin. The ingredients, which are the largest in the product, are located at the beginning of the composition. For daytime skin care around the eyes, choose a tool with a transparent gel texture. It should cope with edema and contain a UV filter. As a night remedy, choose active serums and creams that moisturize and nourish the skin. Do not use a product that is not appropriate for your age, this will only aggravate the situation and worsen the general condition of the skin. On the packaging of the cream for the eyes should be information that the cream contains a hypoallergenic formula and has passed ophthalmic control. The cream for the skin around the eyes should be with a roller applicator or be in a tube with a thin nose. The tool will be less in contact with oxygen, which will reduce the risk of allergic reactions and infection after its use. When choosing a cream for the skin around the eyes, ask the seller to provide you with a sample of this product, then you can fully evaluate its effect on your skin. There is no guarantee that any universal cream is right for you. The skin after applying the cream should not be dry and tight. At the slightest redness and tingling of the skin around the eyes, stop using this cream, it does not suit you. If the choice of a cream for the skin around the eyes was unsuccessful several times, consult a dermatologist who will choose the product taking into account the characteristics of your skin. Mechanical facial cleansing is a cosmetic procedure.
1 - 1 of 1 Posts
